Use the following procedure to display the active Controllers and Gateways in the SPBM domain.
  1. To enter User EXEC mode, log on to the switch.
  2. Display the SPB-PIM Gateway active Controller and Gateway Nodes:
    show ip spb–pim–gw node [controller | gateway] [spb-node-as-mac]
Display all node lists:
Switch:1>show ip spb-pim-gw node
                                   Spb-pim-gw Active Controller/Gateway
HOST-NAME        Role
BEB3-4037        Gateway
BEB5-4011        Controller
Total Number of Nodes = 2/2
Display Controller node lists only:
Switch:1>show ip spb-pim-gw node controller
HOST-NAME        Role
Total Number of Nodes = 1/2
Display Gateway node lists only:
Switch:1>show ip spb-pim-gw node gateway
HOST-NAME        Role
BEB3-4037        Gateway
Display all node lists with MAC address:
Switch:1>show ip spb-pim-gw node spb-node-as-mac
HOST-NAME        Role            Mac Address
BEB3-4037        Gateway         00:37:00:37:00:37
BEB5-4011        Controller      00:11:00:11:00:11
Display Controller node lists with MAC address:
Switch:1>show ip spb-pim-gw node controller spb-node-as-mac
Display Gateway node lists with MAC address:
Switch:1>show ip spb-pim-gw node gateway spb-node-as-mac
